2003 Lincoln Town Car Right Rear Axle Leaking fluid and mak
2003 LINCOLN TOWN CAR
71,895 MILES • V8 • 2WD • AUTOMATIC
BUTCHE106
While driving on this past sunday, I started to hear a clicking noise in the rear of my 2003 Lincoln towncar. After I stopped, I examined the right rear wheel well and it had fluid all over the wheel well, tire and rotar, brakes. 1) repair shop said that I needed a "Right Rear Axle" and "Brake Pad Replacement". 2) Said that all I needed was a "Rear Axle Seal and Bearing Kit". Now I'm confused. Any answer's or suggestions would be greatly appreciated!
Aug 27, 2009 at 2:29 AM
RACEFAN966
  • 5,029 POSTS
OK what they are saying is that the rear axle seal is leaking. So what they want to do is pull the axle inspect it and replace the bearing and seal. Now if the axle is grooved then you will to put in a new or good used axle. The brake pads need to be replaced because they are now soaked with gear oil. How much do they want to charge? I will look it up to make sure it isn't to much.
Aug 27, 2009 at 3:36 AM
