2001 Lincoln Town Car SUSPENSION PROBLEMS
JUANSS
  • 2001 LINCOLN TOWN CAR
  • V8
  • 67,000 MILES
HERE IS MY PROBLEM. I HAVE A 2001 TOWNCAR THAT HAD REAR END DAMAGE. THE BODY SHOP REPAIRED THE DAMAGE AND INSTALLED A NEW DIFERENTIAL IN IT BUT NOW THE SUSPENSION ISN'T WORKING. I CHECKED THE RELAYS, FUSES, HIEGHT SENSOR, AND CAN UP WITH NOTHING. THE ONLY OTHER THING I NOTICED IS THE CONNECTION TO THE COMPRESSOR HAS FOUR PINS AND ONLY ONE HAS POWER( ABOUT 5 VOLTS) EVEN WITH THE KEY TURNED AND THE CONNECTION TO THE HIEGHT SENSOR ALSO HAS FOUR PINS AND THREE HAVE POWER TO THEM ( ABOUT 5 VOLTS A PEICE) WITH AND WITHOUT THE KEY TURNED. THE SUSPENSION WAS FINE BEFORE IT GOT TO THE BODY SHOP BUT NOW IS AS I DESCRIBED IT. ALL I CAN COME UP WITH IS THAT THERE IS A SHORT TO VOLTAGE. AM I OVERLOOKING SOMETHING, OR HAVE I DONE ALL AND NOW NEED TO FIND THE SHORT?
Sunday, March 30th, 2008 AT 10:46 PM
FLEXY5
  • 512 POSTS
Does it come up with a system warning? Have you checked the switch that turns the system off? I know you stated that you checked the height sensor, but I would check the rear one again. The sensor should only have 5 volts going to it. Check the sensor arm and make sure it is attached to the rear differential housing.
Monday, March 31st, 2008 AT 9:27 PM
