When the gas pedal is let off the car stalls
62,000 MILES • V8 • 2WD • AUTOMATIC
DMBLP
Car will only start and run with gas pedal pressed. When the gas pedal is let off the car stalls. Code reader said no codes
Mar 16, 2010 at 10:38 AM
  • 55,694 POSTS
This sounds like one of two problems can be happening either you have a vacuum leak or the IAC motor is dirty and needs to be cleaned.
Here are three guides to help us get the problem fixed
and
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
and
https://www.2carpros.com/articles/stall-at-idle
Please run down these guides and diagrams and report back
Cheers, Ken
Feb 19, 2018 at 11:55 AM
