2001 Lincoln Town Car intermittent blower
104,000 MILES • V8 • 2WD • AUTOMATIC
JRELIHAN3
  • 15 POSTS
today the blower for the htr / ac just stopped working. After I shut the car down, checked the blower eatc fuse, it worked until the next time I got into the car. I made a short trip, no blower. About 2 hrs later, another short trip, blower worked. All seems to be well behind the cntrl panel, all indicators work, I can hear vacum actuaters working & the ac clutch cycles. would this be a cntrl module failure? maybe a relay somewhere? I don't know, thanks for any help
Nov 6, 2009 at 11:41 AM
MATHIASO
  • 1,209 POSTS
Either the switch , the blower motor is on his way out if irratic in all setting or a bad ground at the blower motor resistor assembly. if this happens in only one setting,then resistor may be the problem. Most likely is the blower motor. start doing this: Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection. Disengage the wire harness connectors from the retainer. Disconnect the blower motor electrical connector. Remove the motor cooling hose. Remove the screws and remove the blower motor Remove the wheel from the blower motor as follows: Remove the push clip. Remove the wheel from the blower motor. Blower motor cooling hose
https://images.2carpros.com/forum/automotive_pictures/46384_0900c152801e5f16_1.jpg
Blower motor mounting plate
https://images.2carpros.com/forum/automotive_pictures/46384_0900c152801e5f17_1.jpg
To install with the new blower. Install or connect the following: Wheel to the blower motor, if removed. Blower motor and securely tighten the screws. Motor cooling hose Blower motor electrical connector Wire harness retainers
Nov 6, 2009 at 12:35 PM
JRELIHAN3
  • 15 POSTS
where is the resister for the motor located? Attached to the motor housing?
Nov 7, 2009 at 12:28 PM
MATHIASO
  • 1,209 POSTS
The resistor for motor is located under the passenger side of the dash. You must remove the lower dash insulator panel to see the resistor. The resistor is located right at the firewall so the inside screws can be difficult to access. The resistor block mounting tabs are slotted on the firewall side so you do not need to remove those screws completely to remove the resistor block.
https://images.2carpros.com/forum/automotive_pictures/46384_blower_resistor_block_1.jpg
Nov 7, 2009 at 7:16 PM
JRELIHAN3
  • 15 POSTS
natch, the thing worked till just about dark-30; when it quit, I put the fluke on the connector plug, with the black test lead grounded to the neg side of the battery; 1 wire read 11.7 & the other about .3. The blower speed selector was on "max". This was with with the ignition turned on & car not running, temp set to highest value & floor position button pushed. The schematic shows 2 wires gong to motor--1 for max & the other back roured thru thru resistor bank to the selector switch. I am about 98% sure this indicates a faulty motor. What are your thoughts?
Nov 8, 2009 at 9:38 AM
MATHIASO
  • 1,209 POSTS
yes sir ;-)
Prior to removing a wheel that is to be reused, clean any corrosion from the blower motor shaft to prevent damage to the wheel mounting shaft.
you did a good job.
Nov 8, 2009 at 10:04 AM
JRELIHAN3
  • 15 POSTS
I cannot get to the bottom screw w/o removing the wheel liner (it appears) there is not enough room either for my hand and/or tools. Is there a secret to getting this thing out?
Nov 11, 2009 at 8:54 AM
RICKMAR
  • 170 POSTS
Possibly your blower motor resistor is stuck. Turn the switch on with the a/c on high, with the engine off, then hit the blower motor resistor. The fan should start working. Resistor is located on the fire wall behind the right valve cover. Also behind the heater hose. It's about the size of a deck of cards. Put a screw driver against it and then tap the screwdriver….hopefully the fan will start !! Good Luck
Rick
Nov 11, 2009 at 3:17 PM
JRELIHAN3
  • 15 POSTS
I am NOT a happy camper. Bought a new blower motor, hooked it up before installing and it did not work. I tapped the module behind the valve cover & the blower started woorking. When it did not work a short while later, a small tap started the blower again so it appears that the module is faulty, NOT the blower motor. now that we know what it is, what is the proper name for this thing so I can get another one. Thanks
Nov 15, 2009 at 9:31 AM
MATHIASO
  • 1,209 POSTS
I can't see no module behind the blower moter unless it is the pcm!
Do you have a way to take picture of it?
Nov 15, 2009 at 10:52 AM
RICKMAR
  • 170 POSTS
[quote:9cbc6697d2="jrelihan3@yahoo.com"] it appears that the module is faulty, NOT the blower motor. now that we know what it is, what is the proper name for this thing so I can get another one. Thanks[/quote:9cbc6697d2]
It is called a "Blower resistor"
Rick
Nov 15, 2009 at 4:36 PM
MATHIASO
  • 1,209 POSTS
https://images.2carpros.com/forum/automotive_pictures/46384_46384_blower_resistor_block_1_1.jpg
I posted this picture for few days ago, this the resistor I asked to check. it should look like this one in the pic.
Nov 15, 2009 at 7:43 PM
JRELIHAN3
  • 15 POSTS
I don't have a photo-it is located to the rt of the blower underneath the vacum hoses almost directly behind the rt valve cover-there is also a water hose somewhat in the way. it has a red / white sticker on it. just a tap & the blower kicks in everytime. I have been told it is a blower control module and an a/c temp control module & have been quoted prices from $95 - $165 for a used replacement--i shudder to think what a new 1 will cost
Nov 16, 2009 at 11:21 AM
MATHIASO
  • 1,209 POSTS
sorry i could not find that one.
you probably need to replace it,
or maybe a used one, but no guaranty.
Nov 16, 2009 at 6:21 PM
RICKMAR
  • 170 POSTS
Hi jrelihan3;
I am glad the little tap on the resistor I told you to try worked for you.
It was posted by me for you to read on Sunday Nov 15, 2009 10:36 pm.
The little black plastic box with a red / white sticker on it is a (Blower Motor Resistor Switch).
The original replacement part
AC DELCO Part Number: 1550635
https://www.2carpros.com/forum/automotive_pictures/433905_blowerresistor_1.jpg
Alternate/OEM Part Number: 19139912
OEM is (Original Equipment Manufacturer)
The good news is the price ("Hold on to your seat") ready ? >>>>>>>>>>
$10.00 - $16.00 !!!!!!!!! "BRAND NEW"
FOUR SEASONS Part # 35928 $10.34
AC DELCO Part # 1550635 $15.99
BOTH AVAILABLE AT WWW.ROCKAUTO.COM.
I would go with AC Delco (Good Brand Name)
Before you order the Blower Motor Resistor I would call Rock Auto Parts 1-866-ROCKAUTO (762-5288) before you order to make sure you are ordering and will be receiving the right part.
Give them a credit card number or send them a check or money order and you will have your "NEW" replacement part.
Avoid purchasing from a dealership for any part whenever you can.
WHENEVER YOU GO TO A DEALERSHIP TO PURCHASE PARTS YOU WILL ALWAYS PAY A "BIG" PRICE !!
I hoped the information helped you out.
Good Luck :
Rick
Nov 17, 2009 at 12:30 AM
JRELIHAN3
  • 15 POSTS
everything I was told was WRONG. It was NOT the motor, NOT a resistor, NOT a switch. What it IS is a BLOWER CONTROL MODULE as I found out when I removed it. I was able to repair it by soldering back a loose solder point.
Dec 21, 2009 at 2:44 AM
NOONWITHCARS
I have a 2001 Lincoln Town car...the head light stay on when the car is turned off and the signal light and dashboard don't work ..can anyone help me
Mar 27, 2016 at 3:32 PM
