2001 Lincoln Town Car Faltering
100,000 MILES • V8 • 2WD • AUTOMATIC
BRUCE JAMIESON
My car falters at between 40 and 55 miles per hour. When i step on the gas hard it works ok. Plugsare new, fuel pump is ok,plug wires are new, computer is ok, gas filter is new.
Thanks
Bruce
Aug 2, 2009 at 11:02 AM
JRELIHAN3
  • 15 POSTS
had same problem; changed plugs, pcv ,fuel & air filters;also cleaned sensor connectors; fixed the problem;did you check plug boots?also you can try www.lincolnsonline.com
Aug 2, 2009 at 11:57 AM
