engine hesitates or misfires
99,083 MILES • V8 • 2WD • AUTOMATIC
JRELIHAN3
  • 15 POSTS
engine hesitates / misses at speeds between 40 and 45 mph. in all other aspects, car performs as it should
Jul 11, 2009 at 10:13 AM
There are a number of things that can cause misfires or hesitation, but the basic items are injectors, fuel pressure, spark plugs, and vacuum leaks.
So, I will attach all this info here, but we should start with pulling the plugs and inspecting them.
I will attach a chart that will help tell us if they are an issue.
https://youtu.be/4ktw1X4W_-k
https://www.2carpros.com/articles/how-to-change-spark-plugs
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Please pull the plugs and see what they look like. If they are okay then run through the rest of this info and we can go from there.
Thanks
Apr 19, 2022 at 11:05 AM
JRELIHAN3
  • 15 POSTS
Changed the plugs/air filter/etc. Worked wonders! The back plugs were tough to get out/in but all in all a satisfying job. Thanks so much for your help.
