cruise control buttons
2001 LINCOLN TOWN CAR
125,000 MILES • V8 • 2WD • AUTOMATIC
VERNON CASTLEMAN
How do you replace the cruise control buttons on the steering wheel ?
Jul 24, 2008 at 7:55 PM
DJFINESSE80
  • 34 POSTS
Disconnect the battery first to disarm the airbag system. Here are diagrams to help you see how to replace the cruise control switches below.
Cheers
Jul 30, 2008 at 4:18 AM
CLARK BEATTIE
Thank you in advance for helping me out with this problem. History: The cruise would not disengage at seventy mph. I did a dumb thing and stomped on the brakes instead of pressing the off button on the cruise. I heard a pop from the engine compartment. The cause for the cruise not to disengage was a broken wire on the brake pedal switch. I repaired the wire and now my cruise does not work. I have replaced the servo assembly with a used one and same results. Still does not work. I have checked all of the fuses under the dash and in the engine compartment. I have checked all of the switches on the steering wheel. All are in good working order. Do you have any suggestions?
Jul 6, 2018 at 3:01 PM (Merged)
CRITTER9
Sir: There is a recall out there for your Lincoln's cruise control. There is some faulty relay and the factory is replacing the cruise system free as a result. My 1993 has been to the dealer and been disabled until the new parts come in. No charge to the owner!
