2001 Lincoln Town Car car wont start
165,000 MILES • V8 • 2WD • AUTOMATIC
SDZEPHYR
car had a problem starting when I went to work in morning. Sounded like it wanted to start but wouldnt turn over, let rest a minute then started right up. leaving from work car would not start again, waited a few minutes, same kinda sound, then started. Now wont start at all. Still sounds like it wants to start but wont turn over. All int./ext. lights work bright and dont dim when I turn the key. Please help...
Apr 25, 2010 at 11:48 AM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/COP/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Apr 26, 2010 at 8:44 PM
