2001 Lincoln Town Car blower mtr will not come on
44,000 MILES • V8 • 2WD • AUTOMATIC
BRADYYYY
i have put a new blower mtr in and it stitt want work have check fuses all good
Apr 19, 2008 at 11:27 AM
MERLIN2021
  • 17,250 POSTS
Did you read my answer to your first post? Now try this and post the code you get, Run the self diagnostic test on it by turning the key to on, then press off and floor at the same time, then within 2 secs, press auto, If there is a problem a trouble code will appear on the display...To exit self test, press the BLUE, cooler button this also retains error codes, To erase code and exit, press defrost, choose one of these before you power down the system...post any codes recorded here and I will give you the problem!
Apr 19, 2008 at 11:34 AM
