2001 Lincoln Town Car
95,000 MILES • V8 • 2WD • AUTOMATIC
BROCKTYRONE
When I drive my 2001 Lincoln Towncar it pulls to the right. I have had it aligned and it still pulls right. I have had a new pitman and idle arm replaced also and it still has the same problem. The tire on the front passenger side is turned to the right when it is parked and all the other wheels are straight. and when i drive the car I have to keep a grip on the steering wheel , because it will move to the right lane
Apr 13, 2008 at 2:43 PM
FLEXY5
  • 512 POSTS
Try moving the left tire to the right and right to left. If the pull follows the tire, replace the tire toward the pull. It may not be that far off alignment, but if this doesn't resolve the issue, you may want to consider taking it somewhere else to have the alignment done.
Apr 13, 2008 at 2:50 PM
