2001 Lincoln Town Car
31,000 MILES • V8 • 2WD • AUTOMATIC
BOOGERMAN36105
the key pad.. door conbination.. interior lights and manual inside door locks will not work..Driver side
auto down window stops if you take finger off button...please help...Somebody said body or
frame module around $1000..Sure hope not..
Thank You Boogerman
Mar 22, 2008 at 4:42 AM
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
Sounds more like th drivers door module...
Mar 22, 2008 at 4:50 AM
MERLIN2021
  • 17,250 POSTS
Answer to PM: Get the PCM data read at any garage that can read "B" codes, b4 you start spending money, it could also be GEM module...
Mar 24, 2008 at 5:25 AM
