2000 Lincoln Town Car Radiator Stop Leak
2000 LINCOLN TOWN CAR
GREATNESS_UNMATCHED
Engine Cooling problem
2000 Lincoln Town Car 4 cyl Four Wheel Drive Automatic
I am trying to place radiator stop leak into my radiator. But the radiator has only one access point which is the reservoir connected to the radiator. Do I place the stop leak directly into the reservoir seeming it is the only access point I have to the radiator?
May 24, 2010 at 10:38 AM
  • 31,937 POSTS
Yes that is where it goes, but i would advise not to use it as this muck can cause more harm than good, it can block coolant passages and lead to further over heating problems, get the radiator repaired properly this will in the end save you money.
Mark (mhpautos)
May 24, 2010 at 10:41 AM
