2000 Lincoln Town Car cooling intermittent
2000 LINCOLN TOWN CAR
98,000 MILES • V8 • 2WD • AUTOMATIC
JCH7830
heard a clicking sound behind the glove box for several weeks. Now when I lower the temperature for the air conditioning it take several minutes (30-45) before it starts cooling.
Apr 24, 2009 at 4:38 AM
MERLIN2021
  • 17,250 POSTS
Run the self diagnostic test on it by turning the key to on, then press off and floor at the same time, then within 2 secs, press auto, If there is a problem a trouble code will appear on the display...To exit self test, press the BLUE, cooler button this also retains error codes, To erase code and exit, press defrost, choose one of these before you power down the system... Test with engine at 120 degrees or more, and cabine between 40-90 degrees.Post any codes recorded here and I let you know what's defective...
Apr 24, 2009 at 8:43 AM
