There is a random clicking that sounds exactly like a turn signal relay under my dash from a module to the right of the steering wheel. Sometimes the speed of it varies. It happens when climate control is on or off. It happens in any shifter position (PRND21). When you press on the brake pedal it stops. When you turn on a turn signal the turn signal (rhythmic sound) prevails. Everything seems to run properly except the driver side seat motor gear is stripped. This has been a faithful old car. I would like to keep it a while longer. Any help would be appreciated. David
Oct 7, 2008 at 2:30 AM
