Electrical problem
1999 Lincoln Town Car V8 Two Wheel Drive Automatic 200k miles
Have Headlights, have brake lights, however no tail lights or markers? Checked every fuse under dash. Check fuses and relays under hood. Looked for a fusible link under driver side door threshold. Looked for a trouble code with an OBD scanner, found nothing?
When the switch is disconnected from the wiring harness I should have all lights controlled by the switch on. Headlights are on, Lights On Bell is ringing no tail lights? I've tried auto position as well as every other position.I've switched the light switch with a known working switch, same make & model. Apparently, the switch is not the issue?
Please advise-Thanks
Nov 24, 2009 at 7:14 AM
