1999 Lincoln Town Car Cannot Shift out of Park
1999 LINCOLN TOWN CAR
138,000 MILES • V8 • 2WD • AUTOMATIC
FRANKR
Car starts and everything seems normal but you cannot get shift lever out of park position. The Break pedal has been applied before attempting to shift into reverse.
I suspect break sensor on pedal or linkage.
Dec 29, 2008 at 9:12 AM
LKB4147
had same problem on 2000 lincoln. it was the sensor near the break pedal. i could get the car out of park if i put the key in and turned it to accesory and then put car in neutral to start. once started i could shift to drive
Jan 12, 2009 at 12:45 AM
LAYNERD
  • 5 POSTS
Read you owner's manual and it will tell you how to shift it out of park. You likely have a light out on the rear or a bad brake light switch.
May 29, 2009 at 3:11 PM
