1998 Lincoln Town Car Turn Signal and Brake Lights
OZARK
Brakes problem
1998 Lincoln Town Car Engine Size unknown Wheel Drive Type unknown Automatic 80000 miles
My turn signal and brake lights are not working. The middle brake light works but the ones on the back lights do not. Additionally my turn signal does not work either. It will turn on but not blink. These are not related to a fuse or a light bulb being out, those areas have been checked.
Jan 23, 2008 at 11:07 AM
BMRFIXIT
  • 19,053 POSTS
[quote:37ce172ead="Ozark"]Brakes problem
My turn signal and brake lights are not working. The middle brake light works but the ones on the back lights do not. Additionally my turn signal does not work either. It will turn on but not blink. These are not related to a fuse or a light bulb being out, those areas have been checked.[/quote:37ce172ead]
put on the 4 way flasher and try
you need a combo switch (signal switch )
easy to do
let me know
Jan 23, 2008 at 11:11 AM
OZARK
[quote:bd7ad79576="BMRFIXIT"][quote:bd7ad79576="Ozark"]Brakes problem
My turn signal and brake lights are not working. The middle brake light works but the ones on the back lights do not. Additionally my turn signal does not work either. It will turn on but not blink. These are not related to a fuse or a light bulb being out, those areas have been checked.[/quote:bd7ad79576]
easy to do
let me know[/quote:bd7ad79576]
Thank you. However that did not work. Any other suggestions
Jan 23, 2008 at 11:21 AM
BMRFIXIT
  • 19,053 POSTS
[quote:8a573bb53f="Ozark"][quote:8a573bb53f="BMRFIXIT"][quote:8a573bb53f="Ozark"]Brakes problem
My turn signal and brake lights are not working. The middle brake light works but the ones on the back lights do not. Additionally my turn signal does not work either. It will turn on but not blink. These are not related to a fuse or a light bulb being out, those areas have been checked.[/quote:8a573bb53f]
easy to do
let me know[/quote:8a573bb53f]
Thank you. However that did not work. Any other suggestions[/quote:8a573bb53f]
did you change the switch?
if not do it
Jan 23, 2008 at 11:45 AM
