1998 Lincoln Town Car surge
199,000 MILES • V8 • 2WD • AUTOMATIC
DAVE BOY
hi i have a 98 lincoln towncar and when the engine warms up it has a surge around 30-40 mph i replace spark plugs all coils and boots fuel and air filter cleaned the whole throtle body even took it to a repair shop, no lights are on and also cleaned the maf sensor but did not replace, i think it's a trans problem i read that these trans on the 4.6 motors have a oss sensor that goes bad can some one please help so i won't pull the little bit of hair i have out?
o forgot to mention runs like a top at idle
Jul 4, 2010 at 10:51 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jul 4, 2010 at 8:15 PM
