1997 Lincoln Towncar Signature Edition
SCOOBY87112
My fuel pump is not work and I need to get it replaced asap. Is there a diagram to repair it or can you please tell me how to replace it. Also is there an access panel in the car or is it necessary to drop the fuel tank? Than kyou so much. i appreciate it so much.
Feb 12, 2007 at 3:58 AM
SQUAW504
[quote:a45690080d="scooby87112"]My fuel pump is not work and I need to get it replaced asap. Is there a diagram to repair it or can you please tell me how to replace it. Also is there an access panel in the car or is it necessary to drop the fuel tank? Than kyou so much. i appreciate it so much.[/quote:a45690080d] Hello it is not hard to change your pump, jack up your car put jackstands on thr frame rails let the jack down so your rear wheels drop, Unbolt plate on front of tank and remove fuel pump, try not to bend the float when removing the pump from the tank you can leave it attached, Price about 125.00 with screen. Good luck
Aug 20, 2007 at 5:41 PM
