ball joints
BOSCO133
In the last three months, I have had the bearing go on the driver side front twice. It sounds like it may be a problem again. I am confused, is this common, what else could be the problem.
Jul 18, 2008 at 4:51 PM
  • 31,937 POSTS
Hi there,
If the same work shop is fitting the bearings, i would be checking that they are doing it properly and the problem is not from the bearings being fitted incorrectly, they should last years not months.
mark (mhpautos)
Jul 18, 2008 at 5:28 PM
MERLIN2021
  • 17,250 POSTS
FRONT WHEEL BEARINGS Front wheel bearings are a hub unit design and are pre-lubricated and sealed. Bearings do not require scheduled maintenance. Bearings are preset and cannot be adjusted.
Jul 18, 2008 at 11:47 PM
DJFINESSE80
  • 34 POSTS
IF ONLY LAST FOR MONTHS, CAR MAY HAVE BEEN IN MAJOR ACCIDENT, WITH MAJOR AND UNREPAIRABLE FRONT END DAMAGE(FRAME BENT) GET A CARFAX REPORT
Aug 10, 2008 at 7:46 PM
