1997 Lincoln Town Car back up light switch
165,000 MILES • V8 • 2WD • AUTOMATIC
LINCNUT4
where is the back up light switch located
bulbs good - no lights
is there a relay that may be faulty?
Thanks for any help
Mar 12, 2009 at 9:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The neutral starting/back-up light switch is screwed into the side of the automatic transaxle. You can try checking your fuses but there is no relay. If the reverse lights are both out and fuses/bulbs are good then it is the back-up light switch or wiring to the switch that is faulty.
Thanks for using 2CarPros.com!
Mar 12, 2009 at 10:44 AM
