I seem to developed a problem with my air conditioner. Went I turn on the air conditioner it starts to work okay cold air will come out of the vents. But after about 5 minutes maybe it begins to thrown hot air. Then sometimes it throws cold air again for a while then maybe hot air again. it works then it doesn't It seems to work better when the outside temp. is not real hot. But it still works then it doesn't. Does the fan clutch have something to do with it. I car does not overheat. Hope you have an answer. Thank you John
Aug 23, 2010 at 3:07 AM
