1997 Lincoln Town Car
1997 LINCOLN TOWN CAR
19,000 MILES • V8 • 2WD • AUTOMATIC
PATROLUNIT_98
I seem to developed a problem with my air conditioner. Went I turn on the air conditioner it starts to work okay cold air will come out of the vents. But after about 5 minutes maybe it begins to thrown hot air. Then sometimes it throws cold air again for a while then maybe hot air again. it works then it doesn't It seems to work better when the outside temp. is not real hot. But it still works then it doesn't. Does the fan clutch have something to do with it. I car does not overheat. Hope you have an answer. Thank you John
Aug 23, 2010 at 3:07 AM
BLUECOLLAR
  • 86 POSTS
Theres allot of variables that come into play here, but it sounds like it has a leak and is low on freon. When this happens, depending on how low on freon it is, it may freeze you out of the car in the evening or maybe even when its raining....but not do hardly anything in the heat of the day.
In the hottest part of the day, let the car run with the a/c on max air, high blower for awhile and pop the hood. Have someone hold the throttle at a high idle. Look for the a/c compressor(has 2 lines coming out=one going towards frt. of car and the other to the cab) under the hood and see if you see & hear the a/c clutch engage(click) on and off pretty fast.
If this is happening, most likely you have a leak and your low on freon.
Aug 25, 2010 at 9:55 AM
