1996 Lincoln Town Car hot air when a/c is on
HARRYALBERT
Air Conditioning problem
1996 Lincoln Town Car V8 Four Wheel Drive Automatic
hot air all the time
May 24, 2010 at 11:54 AM
  • 31,937 POSTS
Hi there, check that you have refrigerant in the system, i would be thinking that you may have a leak and the low pressure switch has shut down the compressor, have this check first.
mark (mhpautos)
May 2, 2017 at 4:06 AM
HARRYALBERT
a/c compressor is working but heat coming out of vents
  • 31,937 POSTS
Possibly the heater temp valve is stuck open and this is bleeding hot air into the system, with heater shut off are both heater hoses the same temp to feel?
Mark.
