1996 Lincoln Town Car hot air when A/C is on
HARRYALBERT
  • 1996 LINCOLN TOWN CAR
Air Conditioning problem
1996 Lincoln Town Car V8 Four Wheel Drive Automatic
hot air all the time
Monday, May 24th, 2010 AT 6:54 PM
  • 31,937 POSTS
Hi there, check that you have refrigerant in the system, I would be thinking that you may have a leak and the low pressure switch has shut down the compressor, have this check first.
Mark (mhpautos)
Tuesday, May 2nd, 2017 AT 11:06 AM
HARRYALBERT
A/c compressor is working but heat coming out of vents
  • 31,937 POSTS
Possibly the heater temp valve is stuck open and this is bleeding hot air into the system, with heater shut off are both heater hoses the same temp to feel?
Mark.
