engine runs but won't idle
JRCHILDS
engine starts and runs good but dies at idle. adjusted idle screw about an eighth of an inch and motor continued to run. is there a idle switch or something that has gone bad?
Sep 8, 2010 at 11:06 PM
WRENCHTECH
  • 20,760 POSTS
You cannot adjust that screw. That is just a base idle stop and will mess everything up if adjusted wrong. The idle is not adjustable on this engine and you likely have a bad IAC or EGR valve but at this point your going to have to get a shop to set the base idle stop correctly. This guide can help us fix it.
https://www.2carpros.com/articles/stall-at-idle
May 5, 2021 at 6:18 AM
