1996 Lincoln Town Car eLECTRONIC DOOR LOCKS
150,000 MILES • V8 • 2WD • AUTOMATIC
BSATTERLY
rEMOTES WONT WORK DOOR LOCKS, JUST INSTALLED NEW BATTERIES.
dO THEY NEED TO BE RE-PROGRAMMED?
tHANKS
bj
Feb 2, 2008 at 3:53 AM
MERLIN2021
  • 17,250 POSTS
cycle ignition from off to run 8 times within 10 seconds, ending on run, not
start! just "on" position. All doors will lock and unlock to confirm program
mode, press ANY button on the remote, door locks will cycle to confirm a good
programming, if a second transmitter is to be done just hit any button on it now!
When done programming, and you can do 4 transmitters, turn ignition to off, doors
will lock and unlock to confirm...
Feb 2, 2008 at 4:51 AM
MERLIN2021
  • 17,250 POSTS
The other thing is to make sure you installed the battery correctly!
Feb 2, 2008 at 4:53 AM
