1996 Lincoln Town Car AIR suspension
109,000 MILES • V8 • 2WD • AUTOMATIC
SAINTLEN
THE REAR AIR SUSPENSION WARING COMES ON , ON THE DASH EVERY TIME I START THE MOTOR.
THE SUSPENSION MOTOR DOES NOT RUN & THE REAR OF THE CAR IS GETTING LOWER.
I NEED TO KNOW WHERE TO START TO LOOK TO FIND OUT WHAT IS THE PROBLEM AND HOW TO FIX IT.
FUSE IS OK, NO CODES SHOWING.
THANKS IN ADVANCE FOR YOUR HELP,
AL
May 9, 2010 at 12:44 PM
BMRFIXIT
  • 19,053 POSTS
start by checking fuses and leveling motor relay
check ride sensors under the car
check motor
check for codes
May 9, 2010 at 12:51 PM
SAINTLEN
[quote:6a2dad8032="BMRFIXIT"]start by checking fuses and leveling motor relay
check motor
check for codes[/quote:6a2dad8032]
THERE ARE NO CODES AND WHERE DO I FIND THE MOTOR FOR THE SUSPENSION.
MY REPAIR MANUAL DOES NOT SHOW OR TELL WHERE IT IS.
THANKS
May 9, 2010 at 12:59 PM
BMRFIXIT
  • 19,053 POSTS
need to use a scanner tool for codes an OBDII reader will not get you any codes from the air suspension system
https://images.2carpros.com/forum/automotive_pictures/99387_7005_thumbnail_12.jpg
May 9, 2010 at 1:12 PM
