1995 Lincoln Town Car get lower ball joints out
121,000 MILES • V8 • 2WD • AUTOMATIC
PETE TETLEY
I have rented the ball joint remover and used a 3 foot pipe on a breaker bar and I can NOT get the old ball joint to move at all.
Will some heat help, can I cut a line inside of it to relieve the pressure ( hardened steel ?? )
Mar 10, 2010 at 12:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Are you replacing the upper or the lower ball joint?
The lower ball joint is only supposed to be replaced along with the control arm as an assembly. The lower ball joint alone is not replaceable.
Mar 10, 2010 at 12:28 PM
CARADIODOC
  • 34,391 POSTS
What kind of tool are you referring to? A tapered pickel fork? Ball joint press? Is the replacement ball joint the simple round housing with the ball and tapered stud inside a socket?
caradiodoc
Mar 10, 2010 at 12:29 PM
PETE TETLEY
[quote:5eb49ea215="bluelightnin6"]Hello and thanks for donating
The lower ball joint is only supposed to be replaced along with the control arm as an assembly. The lower ball joint alone is not replaceable.[/quote:5eb49ea215]
Mar 13, 2010 at 2:25 PM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Mar 15, 2010 at 9:17 AM
