1995 Lincoln Town Car COMPRESSOR FOR AIR SUSPENSION
SIMPLMAN
Suspension problem
1995 Lincoln Town Car V8 Two Wheel Drive Automatic
I have gone through a few tech articles and tested everthing from fuses to relays,air bag solenoid ,control unit height sensor etc...
i can jump out the compressor and it works but does not run on its own when hooked up,i have coorect voltage between relay/fuse and control unit also btween control unit and compressor etc...door actuator switches are good i cant find anything wrong
compressor just wont run....
Aug 7, 2008 at 6:36 AM
DJFINESSE80
  • 34 POSTS
U NEED A NEW PUMP. WWW.ARNOTT INC. CALL THEM, AND TELL THEM KEN PRESCOTT REFERRED SO I CAN GET A DISCOUNT HOMIE. IF PUMP IS BA D , SO ARE AIR BAGS
Aug 10, 2008 at 7:19 PM
SIMPLMAN
[quote:eb29fc6045="djfinesse80"]U NEED A NEW PUMP. WWW.ARNOTT INC. CALL THEM, AND TELL THEM KEN PRESCOTT REFERRED SO I CAN GET A DISCOUNT HOMIE. IF PUMP IS BA D , SO ARE AIR BAGS[/quote:eb29fc6045] the pump works when tested on its own only wont work when connected to the rest of the system
Aug 13, 2008 at 8:51 AM
DJFINESSE80
  • 34 POSTS
[quote:1944260408="simplman"][quote:1944260408="djfinesse80"]U NEED A NEW PUMP. WWW.ARNOTT INC. CALL THEM, AND TELL THEM KEN PRESCOTT REFERRED SO I CAN GET A DISCOUNT HOMIE. IF PUMP IS BA D , SO ARE AIR BAGS[/quote:1944260408] the pump works when tested on its own only wont work when connected to the rest of the system[/quote:1944260408]
Aug 17, 2008 at 7:16 PM
DJFINESSE80
  • 34 POSTS
ANY PUMP WILL WORK IF U JUMP IT, REPLACE THE PUMP
https://images.2carpros.com/forum/automotive_pictures/218559_2115384826_s_1.png
https://images.2carpros.com/forum/automotive_pictures/218559_m_bfac118db97d5095beff1f53f16e3594_11.jpg
the pump works when tested on its own only wont work when connected to the rest of the system[/quote:0311ed5f9e][/quote:0311ed5f9e]
Aug 17, 2008 at 7:19 PM
