1995 Lincoln Town Car Airbag readiness lights
193,000 MILES • V8 • 2WD • AUTOMATIC
RICHIS1
The airbag readiness lights are blinking a series of 5-2 blinks for a series of 5 then the light stays on till engine is cut off and then restarted. In case I have not made myself clear it flashes 5 times pauses and then flashes 2 times , that happens 5 times then the steady light. can you tell me what this code means?
Feb 8, 2008 at 10:06 AM
MERLIN2021
  • 17,250 POSTS
52= Intermittent Or repaired lost battery feed. If you plan to work on this, remove negative battery cable for 1 minute before you do! Air bag deployment can happen if you don't!
Feb 8, 2008 at 10:27 AM
