1994 Lincoln Town Car What would make my 94 Lincoln Towncar
210,363 MILES • V8 • 4WD • AUTOMATIC
JUSTINBWILKINS
When I first start the car up, it takes two to three turns til it wants to start. Then I have to wait before i can drive it because it takes along time to warm up and just go. Then, once it starts to go... I can go about 52 to 60 miles per hour and then it will start to decelerate hard where when I give it gas....it rocks and muffles and its hard to accelerate.
May 19, 2010 at 4:55 AM
  • 75,988 POSTS
You sure the transmission is not slipping if not do below
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 19, 2010 at 9:40 PM
