1994 Lincoln Town Car vacuum
14,800 MILES • V8 • 2WD • AUTOMATIC
JULIANMARY
Can hear hissing sound
May 3, 2010 at 4:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Need to hunt it down and repair it. Sometimes hard but if you got a good eye and a little soap and water you can spray all hoses that you see and check for bubbles also you can check with a engine starting fluid and spray a little around intake manifolds with the engine running and if the engine speed raises then you have found the leak also listen for where hissing sounds come from, check for cracked hoses or dry rotted hoses and so on good eye and patients also you can try with a vacuum pump but I usually find the with a little time and a little water and bubbles.
May 3, 2010 at 9:15 AM
