1994 Lincoln Town Car ticking and knocking
265,000 MILES • V8 • 2WD • AUTOMATIC
CHRIS_30240
hello i have a 94 lincoln towncar with the 4.6L it has 265000 miles my grandfather gave it to me when i got it it had a bad water leak i fixed that and the windows among other small things now when i start it it runs very rough when its cold if you let off the gas it dies untill it gets warm it also has a very bad tick to it its very loud and when it goes to die befor it gets warm u can hear a knock to it which either goes away after warming up or is hid by the ticking i want to fix the car on my own becouse he got it as a project car any ideas on what all this could be or what i can do to rule out some things any help would be amazing thank you
Jan 13, 2009 at 11:45 AM
MERLIN2021
  • 17,250 POSTS
Read the codes first for the idle problem, but can be either the idle air control, or the ECT, or a vacuum leak, the ticking and knocking is more serious, and can be worn engine parts, and or a weak oil pump.
Jan 13, 2009 at 11:50 AM
CHRIS_30240
thanks for the help do you think it would be worth fixing
Jan 13, 2009 at 1:29 PM
MERLIN2021
  • 17,250 POSTS
I would'nt want to be the guy that said fixing t T/C with 265,000 miles is a good idea...
Jan 19, 2009 at 4:05 AM
