1994 Lincoln Town Car Door locks
1994 LINCOLN TOWN CAR
14,400 MILES • V8 • 2WD • AUTOMATIC
OCIEJ
The interior lights do not come on when I open a door. Entry code does NOT unlock the doors! When the door panel switch is moved to lock the doors-the front head lights come on!
Dec 29, 2009 at 2:44 AM
MERLIN2021
  • 17,250 POSTS
You need to run this quick test first, then if it points you to a pinpoint test, let me know which one and I will post it.
TESTING To test and service remote keyless entry system, perform the Quick Test first. Perform pinpoint tests only when instructed to by the Quick Test. When pinpoint tests are completed, repeat Quick Test to ensure system is operational. QUICK TEST 1. Lock and unlock each door several times from each individual switch. If doors lock and unlock properly, go to next step. If doors do not lock and unlock properly, go to PINPOINT TEST F. 2. Sit in vehicle with all doors closed. Turn ignition on then off. Turn interior lights on with dimmer switch. Open trunk. If interior and trunk lights come on, go to next step. If interior and trunk lights do not come on, go to PINPOINT TEST E. 3. Use dimmer switch to turn off interior lights. Turn ignition off. Press each button on keyless entry pad, waiting about 5 seconds before pressing the next button. If interior or key hole lights do not come on, go to next step. If all key pad lights come on and interior, and key hole lights come on when first key pad button is pressed, go to step 7). 4. Press each button on keypad. If no key hole lights come on, go to PINPOINT TEST C. If some buttons lit key hole light, go to next step. 5. Press each button on keypad. Wait until key hole light goes off before pressing next button. If key hole lights came on with all buttons, go to next step. If one or more buttons failed to light, go to PINPOINT TEST D. 6. Press each button on keypad. If interior and key hole lights come on, go to next step. If interior and key hole lights did not come on go to PINPOINT TEST E. 7. Close all doors and trunk. Ensure all doors are unlocked. Simultaneously press buttons 7/8 and 9/0. Watch anti-theft indicator light (if equipped). If anti-theft light is off when all doors are closed and locked, go to next step. If anti-theft indicator is on with doors closed and unlocked, go to PINPOINT TEST H. If interior lights stay on, go to PINPOINT TEST E. If no doors lock and keypad light stays on, repeat beginning of this step. If still not okay, replace control module and repeat Quick Test. If all doors lock, interior and keypad lights are off, and anti- theft indicator is off with doors closed but comes on for 30 seconds after doors lock and then goes out, go to next step. 8. Ensure ignition is off and doors are closed and locked. Enter permanent entry code on keypad. Open driver's door. If anti-theft alarm sounds, see ANTI-THEFT SYSTEM article in ACCESSORIES/SAFETY EQUIPMENT section. If driver's door unlocks, interior lights come and alarm does not sound when door is opened, go to next step. If driver's door does not unlock or interior lights do not come on, repeat beginning of this step. If still not okay, replace control module and repeat Quick Test. 9. Enter entry code. Within 5 seconds, press keypad buttons 3/4. If passenger doors unlock, go to next step. If passenger doors don't unlock, repeat this step. If still not okay, replace control module and repeat Quick Test. 10. Enter entry code. Within 5 seconds, press keypad buttons 5/6. If trunk unlocks, go to next step. If trunk does not unlock, go to PINPOINT TEST G. If trunk is always open or unlocked, go to NOTE: Keep driver's window rolled down when performing pinpoint tests to avoid getting locked out of vehicle. PINPOINT TEST G. 11. Sit in driver's seat. shift transmission to Park. Close driver's door. With all doors unlocked, fully closed and interior lights off, turn ignition on. Shift transmission to "R" then "D". If doors lock, go to next step. If doors do not lock, depress and release brake pedal. Repeat step 11). If doors still do not lock, reenter entry code. Press and hold keypad button 7/8. Press and release keypad button 3/4. Release button 7/8. If doors still do not lock, go to PINPOINT TEST B. 12. While sitting in driver's seat, transmission still in "D" and ignition on, open any door. Close door. If door locks, go to next step. If door does not lock, go to PINPOINT TEST B. 13. With driver's seat empty, open driver's door. With transmission still in "D" and ignition on, close driver's door. If driver's door locks, go to PINPOINT B. If driver's door does not lock, go to next step. 14. Turn ignition off. Shift transmission into "P". Close and lock all doors. Lift either front door handle to open door. Within 25 seconds, unlock door with key. Get inside vehicle and turn ignition on. If interior lights come on when door handle is lifted and go off when ignition is turned on, go to next step. If interior lights come on when door handle is lifted and do not go off when ignition is turned on, replace control module. If interior lights do not come on, go to PINPOINT TEST E. 15. Turn ignition off. Enter entry code. Within 5 seconds, press keypad button 1/2. This prepares system to accept alternate code. Press buttons 9/0, 7/8, 5/6, 3/4, and 1/2 in sequence. If keypad and interior lights go out after pressing last button, go to next step. If keypad lights stay on, replace module and repeat Quick Test. 16. Close and lock doors. Press buttons 9/0, 7/8, 5/6, 3/4 and 1/2 in sequence. If driver's door unlocks, go to next step. If driver's door does not open, repeat steps 14) and 15). If still not okay, replace control module and repeat Quick Test. 17. Enter entry code. Within 5 seconds, press button 1/2. When keypad light goes out, close and lock driver's door. This will remove alternate code. Press buttons 9/0, 7/8, 5/6, 3/4, and 1/2 in sequence. If doors remain locked, go to next step. If some doors unlock, replace control module and repeat Quick Test. 18. On models with factory anti-theft system, close and unlock all doors. Turn ignition on. Simultaneously press buttons 7/8 and 9/0 on keypad. If anti-theft indicator goes off after 30 seconds, go to next step. If light stays on for more than 30 seconds, replace control module and repeat Quick Test. 19. Turn ignition on. Momentarily insert shorting plug into program connector. Program connector is located behind glove box. If doors lock and unlock, go to next step. If doors do not lock and unlock, go to PINPOINT TEST I. 20. Remove shorting plug from program connector. Turn ignition off. Close and unlock all doors. Press LOCK button on transmitter. On models with anti-theft system, watch anti-theft indicator light. On all models, if all doors lock, interior lights and anti-theft indicator lights off when doors are closed, then come on for 30 seconds after doors lock, go to next step. If doors do not lock even after transmitter button is pressed 3 times, go to PINPOINT I. If anti-theft indicator light does not respond correctly, go to PINPOINT H. 21. Turn ignition off. Close and lock all doors. Press UNLOCK button on transmitter. On models with anti-theft system, open driver's door. On all models, if driver's door unlocks, interior lights come on and alarm remains silent when door is opened, go to next step. If driver's door fails to unlock or interior lights do not come on, replace control module. If alarm sounds, see ANTI- THEFT SYSTEM article in ACCESSORIES/SAFETY EQUIPMENT section. 22. With ignition off, press UNLOCK button on transmitter twice. If doors unlock, go to next step. If doors do not unlock, replace control module and repeat Quick Test. 23. With ignition off, press TRUNK button on transmitter. If trunk opens, go to next step. If trunk does not open, replace control module and repeat Quick Test. 24. Press PANIC button in transmitter. If parking lights flash and horn sounds, go to next step. If parking lights do not flash and horn does not sound, go to PINPOINT TEST J. 25. If more than one transmitter is programmed to control module, perform this step. If only one transmitter is programmed, go to next step. With ignition off, repeat step 23), but press PANIC button of a different transmitter. If horn and parking lights come on then shut off, replace control module and repeat Quick Test. If horn and parking lights do not shut off, go to next step. 26. With ignition off, repeat step 23), but press PANIC button on original transmitter. If horn and parking lights come on then shut off, go to next step. If horn and parking lights do not shut off, replace control module and repeat Quick Test. 27. Press PANIC button on any transmitter. Turn ignition on. If horn and parking lights shut off, go to next step. If horn and parking lights do not shut off, replace control module and repeat Quick Test. 28. Turn ignition off. Close and unlock all doors. Press LOCK button on transmitter twice. If horn sounds and parking lights flash, go to next step. If horn does not sound and parking lights do not flash, replace control module and repeat Quick Test. 29. Turn ignition on. Close and lock all doors. Close and lock trunk. Press UNLOCK button on any transmitter. If any doors unlock, replace control module and repeat Quick Test. If no doors unlock, remote keyless entry system is okay. 30. Place memory seat in position 3 with memory seat switch. Turn ignition off. Place gear selector in "P" or neutral. Press UNLOCK button on second transmitter programmed. If interior lights come on, driver's door is unlocked and seat moves to first position, go to next step. If interior lights do not come on, driver's doors remains locked or seat does not move, go to PINPOINT TEST K. Page 3 of 3 12/29/2009 http://www.ondemand5.com/mric/common/asp/Article.aspx?MOD=REPART&YEAR=1 ...
Dec 29, 2009 at 6:08 AM
MERLIN2021
  • 17,250 POSTS
If you need more help, please reply by hitting the reply to question button and typing your new question...
Jan 4, 2010 at 6:07 PM
JOELMAYBIN
PINPOINT TEST F !
Dec 3, 2012 at 10:04 AM
