1993 Lincoln Town Car Rear window removal
228,500 MILES • V8 • 2WD • AUTOMATIC
KEBELL41
I am trying to replace the regulators in both rear windows. The attacchment point of the window hangs over the top of the regulator thus keeping me from removing the regulator. I'm not sure what or how to move the window enough to get out the regulator. Any help would be great.
May 24, 2009 at 11:37 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Have you drilled the three holes in door to acesss regulator attaching screws?
Let me know
Thanks for donate
May 25, 2009 at 5:24 AM
KEBELL41
I have removed all the rivets. All that is left are the two bolts at the top of the regulator. It is loose but won't go out past the bottom of the glass.
May 25, 2009 at 5:32 AM
DOCFIXIT
  • 18,828 POSTS
O.K.
On the Town car you do not drill out rivets. You drill three 1/2 in. holes to remove mounting bolts then remove assembly from drum housing. Guess you can rivet it back. The lower right rivet is your reference point Go up 4 5/16 in. then over 1 in. first hole.
Go up 3 17/64 in. over 3 1/8 in.second hole.
Go up 1 25/64 in. over 1 11/16 in. third hole.
Remove bolts , remove REG. from mount then remove through hole. Remove from drum and raise window by hand and secure. Repeat steps in rev order to install.
May 25, 2009 at 5:57 AM
KEBELL41
Thanks a lot.!!!!
May 25, 2009 at 8:12 AM
