1993 Lincoln Town Car idles irradically
51,000 MILES • V8 • 2WD • AUTOMATIC
BARON88
  • 10 POSTS
Hello, my ,93 Town Car (111,000 mi., 51,000 on motor) has an idling problem. It idles roughly and the motor wants to die out at stop. Any ideas would be helpful. Thanks, Trent
Jan 1, 2009 at 7:44 PM
  • 75,988 POSTS
Have the idle air control valve/throttle position sensor/PCV and EGR valves checked out-also for vacuum leak
Jan 1, 2009 at 8:20 PM
BARON88
  • 10 POSTS
are the things you suggested common problems?
Jan 1, 2009 at 8:31 PM
  • 75,988 POSTS
Yes Sir-to include an engine that is in badly need of a major tune-up or you can have the IACV and EGR clean out and see what happens The IACV is the component that is suppose to target the idle speed at all times. Could also be a catalytic converter problem etc
Jan 1, 2009 at 8:42 PM
BARON88
  • 10 POSTS
Thanks rasmataz I will check into your suggestions. -Trent
Jan 1, 2009 at 9:04 PM
