1993 Lincoln Town Car cold driving an climbing hills at low
165,000 MILES • V8 • 2WD • AUTOMATIC
DJFINESSE80
  • 34 POSTS
93 town car looses power to a point,it stalls sometimes when first driving from a cold start, but performs normally after 5-10 minutes, also climbing hills at low speed, the engine vibrates,but in passing gear it performs normally,and on straight it vibrates going into 3rd gear[img:77cc944ef3]http://www.2carpros.com/forum/automotive_pictures/218559_MY_PICS_1.jpg[/img:77cc944ef3]
Jul 25, 2008 at 11:13 AM
MERLIN2021
  • 17,250 POSTS
Check the ECT(engine coolant temperature) sensor.
As for the tranny, check the fluid level and the tarnny mount at the tailshaft. When was the last time the fluid and filter where done?
Jul 25, 2008 at 11:22 AM
DJFINESSE80
  • 34 POSTS
[quote:92e65d1ad7="merlin2021"]Check the ECT(engine coolant temperature) sensor.
As for the tranny, check the fluid level and the tarnny mount at the tailshaft. When was the last time the fluid and filter where done?[/quote:92e65d1ad7]UNKNOWN VEHICLE MAINT.,CHECK ENGINE IS ON SOMETIMES, EXHAUST LEAK,CLAMPED WITH VICE GRIPS, AND PERFORMED BETTER,AFRAID 2 CHANGE FLUID DUE 2 165000 MLS, SHOULD I JUST CHANGE FILTER? WAS TOLD IN OLD CARS IF U CHANGE FLUID, WILL CAUSE TRANNY 2 SLIP OR FAIL. TRANNY SWITCHES FINE BUT VIBRATES UPHILL, AND 2ND INTO 3RD, BUT NOT ALLTHE TIME.SUSPECT O2 SENS, OR SPEED SENS ON TRANS, WOULD LOVE 2 MAKE DONATION, BUT GOTTA LOW PAY JOB. THANX 4 YUR HELP
Jul 29, 2008 at 7:53 PM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/forum/1990-lincoln-town-car-check-engine-and-air-suspension-light-vt153395.html?highlight=
You might remember stepping on me on this one...try my suggestion to the air suspension problem...
Jul 30, 2008 at 6:01 AM
