1993 Lincoln Town Car Brake Light
46,000 MILES • V8 • 2WD • AUTOMATIC
LARRY BOOT
the anti lock brake lock light stays on all the time on dash.
Mar 13, 2010 at 3:47 AM
CARADIODOC
  • 34,413 POSTS
The ABS computer monitors a number of things and memorizes a diagnostic fault code when it detects a problem. The computer turns on the warning light to let you know there's a problem, and it shuts the system down.
When you start the engine, a self-test runs. If the warning light does not turn on until the car has been moving, perhaps up to a mile, suspect cracked tone rings by the wheels. If the light comes on rght away, the code(s) will have to be read by a mechanic with the proper equipment to access the ABS computer. The code will lead him to the circuit or system with the problem, not necessarily the bad part.
caradiodoc
Mar 13, 2010 at 4:12 AM
