1993 Lincoln Town Car blue smoke
1993 LINCOLN TOWN CAR
140,000 MILES • V8 • 2WD • AUTOMATIC
JOHN GIPSON
I have just purchased a 93 Lincoln TownCar. It looks great but burns oil pretty bad. (a lot of blue smoke.)
How long could the engine last if there are no repaiirs?
Apr 3, 2009 at 6:42 AM
BMRFIXIT
  • 19,053 POSTS
No way of telling
keep it full of oil will give you the max amount of time
Apr 3, 2009 at 6:44 AM
JOSEPH LENAHAN
  • 9 POSTS
suggestion - have the cylinder compression checked
to determine if the piston rings are shot. Most likely
your valve guide seals need to be replaced- (not as
expensive as a ring job). Go to lincolnsonline.com
and click on to the Tech section & get some good ideas.
Believe it or not this is not high mileage for this motor
- the 4.6 liter V8 is very hearty and can hold double what you have - be patient and check out the web site.
Worse case scenario try using 15W 40 motor oil & I bet
it doesn't smoke as bad --- good luck
Apr 5, 2009 at 1:22 PM
