Beeping noise coming from behind glove box
1992 LINCOLN TOWN CAR
TEDDYBOSTON
Hi there. I recently purchased this car with 134,000 miles. Test drove the car and was fine with no noticeable problems. A few days after getting it home, when I turned the key to the "on" position I noticed an extra beeping noise (not the door open chime) coming from behind the glove box. Removed the glove box and determined the noise to be coming from a blue box, with two wire harnesses connected to it.
*Blue box beeps five times at about one second intervals for about a minute.
*No indication lights lit on the dash.
It may be insignificant to note, but the car has an aftermarket Viper alarm/car stater in it. When I purchased the starter worked fine, now it will not remote start. Alarm buttons still work.
Anyone have any ideas what the problem is?
Thanks for your time.
-Ted
Oct 24, 2007 at 9:31 PM
TEDDYBOSTON
Hey, if anyone is interested, I found out the source of the problem today. It turns out that blue box is the airbag module. May be a bad airbag sensor causing it to beep...............................................................
Oct 26, 2007 at 3:38 PM
