1992 Lincoln Town Car Wheel Speed Sensor
97,900 MILES • 4 CYL • 2WD • AUTOMATIC
AUNTRISH
The Anti-Lock Break light is on. I have had a diagnostic test run. It indicated that I need a wheel speed sensor. Where is this located on my car? Is it difficult to replace on my own? i.e. do I need special tools.
Apr 15, 2008 at 2:16 PM
BMRFIXIT
  • 19,053 POSTS
which one did it say that you need
front or rear
Apr 15, 2008 at 2:40 PM
AUNTRISH
The diagnostic test did not indicate front or back, simply 1 Wheel Speed Sensor. Does my car have more than 1 sensor? When it decides it wants to lock, it locks up tight. All four wheels will not move.
Apr 15, 2008 at 5:31 PM
BMRFIXIT
  • 19,053 POSTS
the most common is a sensor per wheel
check around the calipers for the sensor
but what you need is the code
to pin point the troubled area
Apr 15, 2008 at 10:50 PM
