1992 Lincoln Town Car Please Help!
JUSTME7288
Noises problem
1992 Lincoln Town Car V8 Two Wheel Drive Automatic
My car has been having a loud knock noise.It knocks as soon as i start it up and only gets louder as i accelerate.Ok my car had oil i checked it the day before it happened.I haven't had any oil leaks or anything in that such.So I just want to know if its my engine gone bad from all the years and miliage or if its a less minor problem?
Dec 4, 2008 at 2:36 AM
JASONRAY
  • 213 POSTS
It sounds like a rod is knocking. When the bearing goes bad or wears out, it creates too much clearance between the rod and the crankshaft. This 'gap' is what causes the KNOCK when the crankshaft starts turning. The engine can be rebuilt but this can end up being just as costly as replacing it. You may need a new crankshaft and/or a rod. My recommendation would be to replace the engine. At least with a short block. This is just the lower end of the engine. You can re-use your heads, intake, etc... This is probably the cheapest and most dependable way to fix your problem...
Dec 4, 2008 at 10:26 AM
