1992 Lincoln Town Car No pulses to Injectors
12,600 MILES • V8 • 2WD • AUTOMATIC
JACOBRAN
Auto stopped running while trying to park & has not started since. You can spray starting ing the throttle body & it its. There is not any pulsae signals on any of the injectors. Tested all 8 with light & meter. Most likely problem???
Dec 7, 2008 at 11:53 PM
BMRFIXIT
  • 19,053 POSTS
I would check for power at the injector
see with key on u should have battery power on the injector connectors
and when cranking PCM will ground and pulse the injectors
check fuses
let me know what is missing
Dec 8, 2008 at 10:30 PM
