1992 Lincoln Town Car NEUTRAL SAFETY SWITCH
1992 LINCOLN TOWN CAR
18,000 MILES • V8 • 2WD • AUTOMATIC
JOHNNYK
Can you tell me exactly how to replace one.
Thank you
Jan 12, 2010 at 5:50 PM
Disconnect battery ground cable.
Position transmission selector lever in ``Lo'' position.
Raise and support vehicle, then working from underneath vehicle, disconnect electrical harness from switch by lifting harness straight up off switch.
Using neutral start switch socket tool No. T74P-77247-A or equivalent, remove neutral start switch and O-ring seal by positioning tool over the extension housing area to gain access to switch.
Reverse procedure to install. Torque switch to 7-10 ft. lbs. using tool mentioned above
Jan 12, 2010 at 6:00 PM
