1992 Lincoln Town Car Door Locks
105,400 MILES • V8 • 2WD • AUTOMATIC
TORNILLO
I have owned this car for 16 months now and I cannot seem to find the answer to this problem. There is a keypad on both front doors near the door handle where a code can be entered to unlock the doors from the outside. Previous owner says they had the code written down but they never used it and must have misplaced the codes. My question is. Is there an easy way to erase the old codes and enter a new code that will make this feature work? Seems like such a waste not to use them.
Thanks
Tornillo
Apr 20, 2008 at 7:38 AM
MERLIN2021
  • 17,250 POSTS
The code should be on a small sticker in the trunk, if it's not there for some reason, remove the right kick panel trim and it's on a box ...
Apr 20, 2008 at 7:42 AM
TORNILLO
[quote:d3e41151ec="merlin2021"]The code should be on a small sticker in the trunk, if it's not there for some reason, remove the right kick panel trim and it's on a box ...[/quote:d3e41151ec]
Thanks merlin2021, for fast response. Problem is solved-works great.
Apr 20, 2008 at 8:18 AM
MERLIN2021
  • 17,250 POSTS
Good...your welcome!
Apr 20, 2008 at 7:28 PM
