1992 Lincoln Town Car ABS Failing
1992 LINCOLN TOWN CAR
114,000 MILES • V8 • 2WD • AUTOMATIC
RTSLINGER
have a 1992 Lincoln Town Car the Abs is failing I have little or no brakes feels like I am on ice! Till the ABS light comes on in the dash board.Then the brakes work ok. Is there away to bypass this so the car is working with normal brakes till I can get in to a mech? pull a fuse? disconnect a wire? I need this car for work everyday Thanks Rob
Jan 10, 2008 at 5:54 AM
NICKNICE21
If your Antilock light is on this means you need new front wheel sensors and new brake pads :D . It is extremely important that you get your brakes done especially if you use this vehicle on a daily basis. I use my Lincoln to get back and forth to work, but it's important to maintain your vehicle. Hope this was helpful.
Jan 16, 2008 at 11:00 AM
