1991 Lincoln Town Car Shakes and Backfires Fix
Good hunting and let us know. :)
Happy motoring :)
Suggested Repair
Replace the fouled, rusted spark plugs contaminated by water in the plug wells during the engine wash, and set the gap to 0.054 inch. Keep water, debris, and oil out of the plug holes and combustion chambers. If symptoms remain, inspect for a vacuum leak and check the PCV system.
Conversation Summary
A 1991 Lincoln Town Car began idling roughly and shaking and backfiring at about 5-10 mph after the engine was sprayed with cleaner and the car sat overnight. An expert suggested listening for a vacuum leak and checking the PCV system. The owner found an EGR low-voltage code that was not the cause, confirmed the plug wires were good, and discovered the plugs were fouled and rusted from water in the plug holes and gapped at 0.060 instead of 0.054. New spark plugs solved the problem.
