1991 Lincoln Town Car water pump replacement
1991 LINCOLN TOWN CAR
21,800 MILES • V8 • 2WD • AUTOMATIC
MARKSHENEL
Greetings. I am replacing my water pump. I am taking off the fan blade, BUT it will not come off. When i have done other cars in the past I just remove the 4 or 5 bolts and it comes off the water pump. I have taken off the 4 small bolts but is will not come off? There appears to be an "extension" that attaches to the water pump on this Lincoln. There is a Large 1 1/2 hega shaped extention shaped shaft. MY question is.... Other than the regular bolts what the heck is holding the fan blade on??? Thanks Markshenel
Oct 25, 2008 at 2:39 AM
DOCFIXIT
  • 18,828 POSTS
Your vehicle has an electric fan is it a 1991?
What you describe is an older model. so the big hex nut you described is what holds it on . Big wrench IMPORTANT LEFTHAND THREADS.
Oct 25, 2008 at 6:29 AM
