1991 Lincoln Town Car stalls
65,000 MILES • V8 • 2WD • AUTOMATIC
HEYDONE
i live in a hot climate and if i drive for more than an hour my car will stall and won't start up right for a few hours
Jul 14, 2009 at 3:50 PM
  • 75,988 POSTS
Next time it stalls don't wait look for spark and fuel immediately do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jul 14, 2009 at 9:26 PM
